Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 100
  1. #51
    I thank god i have not gotten it, Its like the plague down here, Everyone is getting and everyone that works in the hospitol is getting it as well..
    Kasher your a trooper, going out most of the night to get your ALPS installed sick and all
    Yes amazing when it spreads it seems to be everywhere. Thanks for getting back to me. I am in bed bored because I cant sleep and feel horrible.
    when I can I will do the default setup.
  2. #52
    Thanks... I was feeling sick about the whole time I was putting it in but just thought it might be something I ate. Etc. Then it hit! Lol. Not fun thats for sure.....
  3. #53
    Well I finally went out and tried switching the sensor ports it did the same thing, beeping from one side, but not from the other. I have checked all connections made sure they are plugged in and locked, and did everything. I don't get it.
    I did what you said BRD also and did the default setup. The ALP doesn't even appear to be updating settings now. Something is strange. Not sure what else to do next.
  4. #54
    Did you run the sensor check to see if it recognizes 2 sensors are connected?
  5. #55
    Behind a LIDAR gun
    Is it the same head, or the same port on the CPU that is having the issue?
    www.Raletc.org
  6. #56
    It is the same head, because I switched the two ports and the same head remained silent.
    I did the manual check, and I heard two beeps but the green light didn't blink twice.
  7. #57
    I also reset to default several time to try and get CPU to recognize the head.
  8. #58
    I must have a bad sensor .
  9. #59
    Behind a LIDAR gun
    Check the din connection.
    www.Raletc.org
  10. #60
    Quote Originally Posted by Yellowcab View Post
    Yes I unplugged and checked connection plugged it back in and made sure it was locked in place
