Results 1 to 10 of 17
    Vertical Heads at Rear ?
    Due to my rear configuration i am planning to place my heads vertically
    Is it really bad or i can go this way ?
    Thank you.
    Behind a LIDAR gun
    You will lose some performance, I wouldn't recommend it
    www.Raletc.org
    Quote Originally Posted by Yellowcab View Post
    Can you give me a % of loss ...i am ready to loose a bit but gain in stealth... we have
    mad dogs here.
    Thanks
    20% loss in performance. Been their done that, not worth the risk
    Behind a LIDAR gun
    Where are you planning on mouthing them?
    www.Raletc.org
  6. #6
    I plan to use a thick piece of clear plexiglass that will channel the receiving\emitting front
    of the head , this piece will fit in the space between the chassis\door.
    This is the general idea , it is hard to explain clealy , i should do more pics when i receive my sensors
    around friday.
    I used the same way with my li and the response toward my osprey is quite good .
    Too bad i dont own a real gun ...i guess nobody in the all province has such tool .
    Name:  2015 plexi.jpg
  7. #7
    Behind a LIDAR gun
    Why not go with a piece of black molded plastic above the license plate
    . Name:  image.jpg
    www.Raletc.org
  8. The Following User Says Thank You to Yellowcab For This Useful Post:
    melbVt (04-09-2014)
  9. #8
    That is also in my plans , i am exploring all the possibilities , even the good old way : under the lip.
    Thanks my friend.
  10. #9
    Put it inside the headlight is more stealthy.
  11. #10
    Quote Originally Posted by L&R View Post
    Great idea , but i cant ....i promised my Wife not to modify\drill the new Suv
    tough i did it on my previous vehicule with Irt:
