Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    Mounting them near the plate will give better
    results then vertical.
    I see no issue with vertical mount on the rear if you are protecting against rear shots from over passes. The issue will be off axis rear shots....
    This is why I run quad rear, 2 vertical and 2 horizontal.
    Sent from my GT-I9505 using Tapatalk
    NYB
    Do they lose power being in the headlight/rearlight?
  4. #14
    Quote Originally Posted by melbVt View Post
    Yes.
  5. #15
    Update :
    i recieved the rear sensors , after all thinking and figuring i went the good old way ,
    adding a small illusion : to cut the contrast i place a stretch of electrical tape :
    Name:  REAR ALP_2.jpg
  6. #16
    Bring them in as close to the edges of the red tail lights towards the CM of the car.
    That will protect you from up close shots that overpasses are known for.
    PS you have the best car for rear head placement for stealth....
  7. #17
    Thanks .
    Stangely i was shot @ the rear only one time in 6 years.
