Quote Originally Posted by Antilaser View Post
You can also learn your SN by doing "Save to USB" or ServiceCode 2-2-2, and then opening your file on the alpupdate.com.
I think the more difficult task is gathering the serial number of the sensors which is not recorded in the setup file and since the serial numbers are on the cables by the Din connections they might not be reachable in many installs.
