Results 1 to 10 of 12
    Onterrible
    LI Keyfob vs ALP System
    Does anyone know if you can use the LI key fob to trigger and or test alerts against the ALP? Just curious before mine goes way of ebay. Auction ends tomorrow.
    Thanks!
    ALP Quint - HiFi
    ALP Triple - HiFi
    STi-R Plus (x2)
    i have the earlier square box type li tester and trigger the alp's ok, not to much help but testing the same thing in away so key fob may work as well
  3. The Following User Says Thank You to dinkydi For This Useful Post:
    Tman (03-28-2014)
    You bet! All it does is is use its IR LED to emit pulse patterns that match those of certain lidar guns, and any jammer which recognizes those patterns will respond accordingly.
    I scope tested mine a little while ago and if you're curious, here's what the patterns look like.
    First off, the keyfob tester itself.
    1) TruSpeed/TruCam: 200.3 pps
    2) PL3/PL4/ProLite+: 200 pps
    3) PL2/Laser Atlanta: 238 pps
    4) Stalker/Stalker LR: 130 pps
    5) LRB/100/200/Compact/Marksman: 125 pps
  6. The Following 10 Users Say Thank You to Vortex For This Useful Post:
    Lucky225 (03-29-2014), Mirage (03-29-2014), Qui-Gon (04-02-2014), RedRocket (03-29-2014), Salty (03-29-2014), shanetrainST (03-29-2014), speed-dreams (03-30-2014), Tman (03-29-2014), winterbrew (03-29-2014), Yellowcab (03-29-2014)
  7. #5
    Hey Vortex
    Always wondered, what is the software you have used to capture the pulses?
    Is it a homemade Ipad scope, with a simple IR receiver circuit connected to the 3.5mm audio jack
    Or is that actually your output from a real scope?
  8. #6
    NYB
    I have 1 too and it works 100% ,
    The Alp is rather strong like a forcefield around your car!
  9. #7
    Hey Vortex
    I imagine he's using an Optical Photo-IR diode ckt. (see Guys of Lidar) & capturing the PRR on a Laptop digital oscilloscope app.
  10. #8
    I use two breakout boards and connect a LI head to them. Then use a picoscope to capture the data. Here are some pics:
    This is an example of my pulse logger.
  11. The Following 2 Users Say Thank You to Mirage For This Useful Post:
    Salty (03-29-2014), speed-dreams (03-30-2014)
  12. #9
    LI, NY
    Thanks!
    Looks like it sold. You can always buy another one. You will love the way the ALP works. I should get the blinder in the wife's car up on ebay.
  13. #10
    Onterrible
    Thanks guys for the info. My LI Dual goes on eBay next week after the ALP Is installed on my other car
    Sent from my Z30 using Tapatalk
    ALP Quint - HiFi
    ALP Triple - HiFi
    STi-R Plus (x2)
  14. The Following User Says Thank You to wolfpacal For This Useful Post:
    Qui-Gon (03-29-2014)
