Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    Hey Vortex
    Always wondered, what is the software you have used to capture the pulses?
    Is it a homemade Ipad scope, with a simple IR receiver circuit connected to the 3.5mm audio jack
    You're spot on. It's done on an iPad, converting an IR photodiode to the 3.5mm audio jack plug and then running an app called "Oscilloscope." Another really good one is "FFT Plot" by the same manufacturer.
    Here's the app in action:
    Here's the components:
    and here it is put together to measure from a KGE instead of Lidar. (The mess of wires on the protoboard also includes other projects. You don't need nearly that many wires...)
  2. The Following User Says Thank You to Vortex For This Useful Post:
    winterbrew (03-29-2014)
    Senior Member CJR238's Avatar
    Dec 2013
    CT
    Does anyone know if you can use the LI key fob to trigger and or test alerts against the ALP? Just curious before mine goes way of ebay. Auction ends tomorrow.
    Thanks!
    Yes it will work with any jammer. If it doesnt there is probably something wrong with your jammer.
    "trust, but verify"
