Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Feb 2014
    Quote Originally Posted by CJR238 View Post
    That would make sense, but for some reason with the same type of scenario he got a front alert when the scatter should have set off the rear.
    I believe the above drawing the blue is approaching the officer as green is passing. In THIS particular scenario BDR is suggesting the the officer was shooting the REAR of a vehicle in FRONT of the car, thus the rear scatters backwards to the front of the green car.
  2. #22
    Quote Originally Posted by Lucky225 View Post
    Direction of travel of both car :Name:  front 2 rear reflection.jpg
  3. #23
    Feb 2014
    Understood, but in the situation described by OP, I believe BDR is suggesting THIS happened:
  4. The Following 2 Users Say Thank You to Lucky225 For This Useful Post:
    curmudgeon (03-28-2014), Tman (03-28-2014)
  5. #24
    Just buy a laser tester , hit the heads with it, and see if it has a delay in the alerts.
  6. #25
    Might not be scatter, sometime they work in groups of two.
    When one is pulling a car over, the second Leo is still hiding in the bushes a little further down capturing speed.
  7. #26
    Feb 2014
    x2, sometimes if it's a divided highway they'll shoot opposite directions from both sides as well and then radio someone else to pull over.
  8. #27
    Correct. Without a Cam and seeing he situation we will never know exactly what happened but if his front alerted and not the rear this diagram will certainly explain it. They could have also been shooting at cars in the opposite lane further down coming towards him and it could have had the same effect. Based on his speed being 35MPH he probably was not the target.
  10. #28
    Feb 2014
    And also I think I'm dyslexic, that was supposed to be BRD
