just messing around while at work with the PL2
I have quad LI upfront..... and 5 head ALp on rear... the Li is set to constant the alp is on the silly 9 second auto shut down normally on test days I do like to set the AL onto constant jam
the first few runs with the LI was with front plate i then flipped my plate and no PTs both front LI PTs first at 31 ft second was at 30 ft with plate and this isn't to good if you encounter the poliscan
i would of loved to got more rear shots but that 1 minute start up is a pain specially when this test wasn't planned all recorded readings on the rear was when the ALP auto shut down after 9 seconds ps i did take a couple of high shots on the rear only because i had added a few things to the car
