Page 47 of 59 FirstFirst ... 37454647484957 ... LastLast
Results 461 to 470 of 582
  1. #461
    Junior Member midd's Avatar
    Oct 2014
    Just noticed there is no RDR option when you select Net Radar as the detector unit.
  2. #462
    Quote Originally Posted by midd View Post
    Its not really needed.. We did not want anything to slow down filtering. KA False Alerts are pretty rare and you can use BS if you want to avoid any really close Cobra false KA's.
    curmudgeon (06-21-2016), modsl55amg (06-21-2016)
  4. #463
    Oct 2014
    ok just wanted to make sure it was disabled, that's all.
    Now I'm getting GPS antenna disconnected and rear radar antenna disconnected alerts. I've unplugged each and reseated them but am still getting the alerts. I noticed the green light on the RG3 module is not lit.
  5. #464
    GPS Antenna needs to be connected to RG3 Module's GPS Port and Antenna 1 in the Front 1 & Rear Ports if you have both antennas. You also need to activate both on the setup page. Each antenna was tested before shipping so you have a configuration issue. Did you also connect the Power Splitter cable?
  7. #465
    South Jersey
    Tom/BRD, if I download the new ALP Control Box firmware release 5.2.5/6.8 ONLY, will it wipe out my present Configuration Profiles A/B/C, therefore requiring me to reload my Configuration Profiles A/B/C ?
    Bump
  8. #466
    Oct 2014
    I'll check again but I know for a fact GPS is in the right spot. I asked about it on RDF.
  9. #467
    Bump
    Possibly. You should always have your settings handy when updating firmware.
  11. #468
    Oct 2014
    Lmao! The cable from the control box somehow disconnected. All is well now! Lol
  12. #469
    South Jersey
    Thanks. I'll load everything to make sure.
  13. #470
    Jul 2015
    California
    So glad i got the BT module Ver 2.0 I just downloaded the APP connected to module FW update done OTA. All done and complete in less then 10min.
