Simple question,yes/ no, will the GPS work now on ios 8.1.1 apple confused, cause mine don't seem to work after update
Did the behavior of the parking sensors change with version 4.5.1? I got a solid red light on my ALP when pulling into the garage today. When I pushed the POWER button once, the light went to flashing (and the parking sensor beeps started up). One more press of the POWER button and the light was back to solid red.
Can you elaborate and I will look into it? After 4.5.1 you lost GPS functionality on your iPhone or after the last IOS update? Does the GPS Function work based on the settings but just not reflect on the app? Need some more information to get to the bottom of it. We have another firmware update scheduled within the next 2 weeks so if the issue is with the 4.5.1 update we should be able to correct the issue quickly in the next update.
Ain't worked for ages since the ios 8 came into play u can get it working by using the privacy work around on the iPhone, but when u disconnect back to no good, one thing I have noticed when u do the privacy Dodge u can set off and get speed kmh reading and the GPS is not even locked on
And this is with the iPhone 6 or older phones? There are tons of issues with the iPhone 6 and AL has been looking into it for weeks but have not had any luck and they believe the issues are on the Apples side. Only some users have issues with others running the same ALP Connect and the iPhone 6 are fine which leads us to believe their might be some hardware differences in certain phones.
