FYI... New Setup option on the ALP update site. Must be running latest firmware (4.4.1 or newer) for the LED Feature:
dinkydi (09-15-2014), Qui-Gon (09-15-2014), winterbrew (09-15-2014)
Was there a Control Set update as well, or just for the Control Box?
STi-R: the ORIGINAL!
AL Priority TRIPLE
ALP Hi-Fi Module
ALP Add-on wish list:
2 more heads
Hy everyone , what do you when you return home after vacations ?
Check what is new ...update is done ...as always a piece of cake
Tom, Just so i understand, Will i now be able to have the LED stay lit while in defence mode or does it just change it so that when you getting painted the led comes on and stays on instead of flash? I ask because i set it to solid and dim and all i got was a solid blue light when hit with Laser and then it went back off.
Ok yes i have the 4.4.1... Ill try again tomorrow and see if i have any luck, Like i said i did the up date and all that and the light would come on blue for apx 10 seconds and then go off. when i hit it with lidar it went blue and stayed that way until the alert stopped.
OK ill mess with it tomorrow, Ive been up since 4am and im not going to mess with it now or i can promise something will end up broken LoL.. Ill check back with you tomorrow and let you know what i come up with ....
Thank you again Tom. You are a true honest good person, I appreciate you taking the time to help when help is needed.
