Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 85
  1. #71
    Senior Member tawwwd's Avatar
    Quote Originally Posted by 991TurboS View Post
    So the receiver can be blocked by plastic dash pieces and still function well? My stock GPS is on the back roof part of the car, not in the dash. If I can conceal the ALP GPS inside the dash, I will do so.
    itll work fine behind the dash
    not sure how your car is exactly but the shark fin on the roof is usually for satellite radio etc...GPS reciever (at least in my vehicles) is behind the nav unit in the upper part of the dash.
  2. #72
    May 2015
    Quote Originally Posted by tawwwd View Post
    Maybe it is the satellite antennae and not the GPS.
    I went ahead and mounted the antenna in the trunk area of the car, which in a 911 is the front. It is sitting under the black plastic cowling lining the bottom part of the front windshield, so it should get a good signal. It is a dry location.
  3. #73
    Member wirelessandy's Avatar
    Oct 2014
    SF, CA
    Quote Originally Posted by dcrolltide View Post
    What if the GPS antenna light is constantly blinking red? Mine blinks roughly every second
    That's normal operation
    I did a quick plug-in test today. Yup, noticed an LED on the GPS antenna itself, and a larger one on the R/G unit.
    Let me see if I understand:
    GPS antenna LED: normal (signal ok) = blinking?
    R/G LED: normal = ____?
    2013 Subaru WRX STI hatchback/ Valentine One / AL Priority QUINT
  4. #74
    Quote Originally Posted by wirelessandy View Post
    Yes, blinking red LED on the GPS antenna = signal OK
    If you're using the HiFi control set, it will also announce if the GPS signal's been lost (I think the LED on the std control set flickers red briefly if this happens)
    My r/g module is tucked away under the dash, so can't remember what that does, although constant green LED comes to mind
  5. The Following User Says Thank You to winterbrew For This Useful Post:
    wirelessandy (05-27-2015)
  6. #75
    Oct 2014
    SF, CA
    No hifi here. Good to know about the antenna blinking! That will be handy.
    Update: Confirmed. I can't see the R/G module either. It's also tucked away now.
  7. #76
    I remember hearing something about time and geotagging alerts with the GPS receiver. Is this feature going to happen, and if so, when? I might have to order a GPS antenna if this feature is added.
  8. #77
    Too many more important things being worked on. Protection is always first before non important features. Eventually stats will be redone but that won't happen until other things being worked on get completed.
    modsl55amg (05-31-2015)
  10. #78
    So does AL Display take priority over this? Acutally, I'm kinda hoping it does, because then I could order the display + GPS antenna in one go and save on shipping
  11. #79
    Display & Stat Logs are at the bottom of a long list of things being developed at the moment.
  12. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    awj223 (06-01-2015), modsl55amg (05-31-2015)
  13. #80
    Jun 2015
    Woodstock, Georgia
    - d e l e t e d -
