Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    Quote Originally Posted by THX1138 View Post
    Here is a shot of the front. Hard to see as the lighting was bad. Genesis sedan Attachment 1084
    Double check the heads and make sure they are pointing straight forward. They appear to be following the lines of the grille which is not optimal.
    The have a slight cant so they are more or less straight forward, but point taken, I will square and level this weekend
    If you cant shim them use the mounting brackets and bend them to keep the heads level and square.
  4. #14
    One easy way to check is to take a picture with a good flash camera and make sure you can see the flat reflection on the head. Also make sure you are standing directly in front of the car dead center!
  5. The Following User Says Thank You to Mirage For This Useful Post:
    curmudgeon (03-14-2014)
