Results 1 to 10 of 14
    Present has arrived
    Install and testing soon....purchased and shipped Friday, arrived on Monday. Excellent service!
  2. The Following 15 Users Say Thank You to THX1138 For This Useful Post:
    BestRadarDetectors (03-10-2014), curmudgeon (03-10-2014), dinkydi (03-10-2014), EightyFiveHundred (03-10-2014), Holla (03-10-2014), JohnBoy (03-11-2014), Mirage (03-10-2014), Qui-Gon (03-10-2014), Radarrob (03-10-2014), Salty (03-10-2014), speed-dreams (03-10-2014), Tman (03-13-2014), winterbrew (03-14-2014), wolfpacal (03-10-2014), Yellowcab (03-10-2014)
    Quote Originally Posted by THX1138 View Post
    Please remember to visit http://www.alpupdate.com and you will need 2 updates (Main Firmware & Control Set Firmware) and 1 setup file. Initially use the Control Module (Not Bluetooth) and can put all 3 files on a blank USB Memory stick and insert the Memory stick and turn on the ALP. It will first update the firmware (Around 60 seconds or so) and then it will reboot. Once powered back on turn it off using the power button on the control module and immediately turn back on. Once powered back on it will update the control set and then load your settings file.
    You are then good to go and you can switch to the Bluetooth Module if you want. Once the heads are all installed in ALP Connect under settings hit the Reset Defaults button so that the ALP will memorize your sensor positions. Let us know if you have any issues.
  4. The Following 5 Users Say Thank You to BestRadarDetectors For This Useful Post:
    curmudgeon (03-14-2014), dinkydi (03-10-2014), Holla (03-10-2014), THX1138 (03-10-2014), Yellowcab (03-10-2014)
    Onterrible
    Congrats on your new purchase!!! BRD is the way to go if you're in the States. Post some photos of the install and most importantly, get it tested before you go out in the wild!
  6. The Following 3 Users Say Thank You to wolfpacal For This Useful Post:
    curmudgeon (03-10-2014), THX1138 (03-10-2014), Tman (03-13-2014)
  7. #4
    Man that is some pretty toys right there.
  8. The Following User Says Thank You to Holla For This Useful Post:
  9. #5
    Please remember to visit http://www.alpupdate.com and you will need 2 updates (*Main Firmware & *Control Set Firmware) and 1 setup file. Initially use the Control Module (Not Bluetooth) and can put all 3 files on a blank USB Memory stick and insert the Memory stick and turn on the ALP. It will first update the firmware (Around 60 seconds or so) and then it will reboot. Once powered back on turn it off using the power button on the control module and immediately turn back on. Once powered back on it will update the control set and then load your settings file.
    *Control Module (a/k/a Control "Set") = ver. 2.9
    *Control Box (a/k/a "CPU") = ver. 4.3.4/4.6
    Above are the latest versions released.
  10. The Following 2 Users Say Thank You to RedRocket For This Useful Post:
    dinkydi (03-10-2014), THX1138 (03-10-2014)
  11. #6
    Very nice pressie,install , upgrade , ready for action
  12. #7
    Member EightyFiveHundred's Avatar
    Feb 2014
    Surf City USA
    Congrats! I think you'll be really happy with your acquisition!
    4 Doors, 10 cylinders, 8500 redline, three pedals, and 206 mph club, plus F/R Black Box G1W-H, RedLine and ALP
  13. The Following User Says Thank You to EightyFiveHundred For This Useful Post:
  14. #8
    Fronts are installed, Bluetooth and app are up and running. Successfully passed my marksman test tonight with JTG. This weekend's mission is to figure out the rear placement and wire routing.
  15. The Following 2 Users Say Thank You to THX1138 For This Useful Post:
    BestRadarDetectors (03-13-2014), Tman (03-13-2014)
  16. #9
    Great, what kid of car you have? Pict of the front end and your install?
  17. #10
    Here is a shot of the front. Hard to see as the lighting was bad. Genesis sedan Name:  alppic.jpg
  18. The Following User Says Thank You to THX1138 For This Useful Post:
    speed-dreams (03-14-2014)
