Results 1 to 10 of 17
    Quote Originally Posted by KrpA View Post
    I'm just saying that if you have serious technical question like this it's better to ask BRD to check with ALP engineering team, than to draw a conclusion form an obviously incomplete method.
    Please don't be so rude to me, I'm shy :-)
    Even at the 60fps I recorded it at, you would see it skip out of sync when firing on and off repeatedly.
    (There would be a ever so slight lag in the flicker).
    You have $500 or so to donate so I can buy a high FPS camera to mod?
    Will be more then happy to accept donations .
    Busta/ST firing my UL at my car non stop at the last few tests confirm no PT or E7 codes .
    Back to it, the point of this test was to confirm IF all 5 heads will fire at once or will it be 3 or 2. .
    But I'm always open to ideas and suggestions.
  2. The Following 2 Users Say Thank You to beingaware For This Useful Post:
    busta (03-06-2014), dinkydi (03-07-2014)
