How can I enter the menu selectable feature on my stalker dual to change Mph to Km
Im the proud new owner of the stalker dual,
However it reads in Mph and I'm looking to run it in km
The manual says it is a menu selectable feature,
I'm not sure if there a combo of buttons to press to enter it,
Hope to find someone who has abit of experience
Please help
MelbVt
The Following User Says Thank You to melbVt For This Useful Post:
sure some of the other guys will chime in, when they wake up have you had a look over on there web site's
The solution to changing Stalker Dual from MPH to KM credit goes to RadarRob!
Video of how to do it http://radarandlaserforum.com/showth...er-dual-to-kph
1st=To do this turn the unit on using power button,
2nd= On bottom of unit you see a hole , Poke something in there to press in the button, You shall see Sen in target window, and a number in middle window, and either Hi or Lo on last screen,
3rd = Press button with Squelch 10 on it press it once then once more if need be or till you see Oc ( Degrees celsius ) If you want it to read in MPH press Squelch 10 till you see Degrees Fahrenheit it look like 0F not a long word! Wait theres 1 more step,
4= Press Hold/Xmit button to save, Then power off and back on and test with tuning fork to verify it's in correct measurement unit
Credits for this goes to our valued member RadarRob Cheers to RadarRob For his time and effort to find how to do this,
Cheers, Cheers Cheers,
From MelbVT
The Following 5 Users Say Thank You to melbVt For This Useful Post:
curmudgeon (03-01-2014), dinkydi (03-01-2014), max (03-01-2014), RedRocket (03-01-2014), winterbrew (03-01-2014)
great forum
- You may not post replies
- You may not edit your posts
Forum Rules
