Many of you that have seen my install know I have recently installed an STI-R Plus Unit, which I am LOVING! I do need help with one thing that I may or may not have to modify. What I have done is use the bracket to mount to the roof with 3M tape. The bracket is taped with the 3M tape to the roof of vehicle as well as the top of the bracket is taped to the bottom of the luggage rail as well. I actually had to remove the luggage rail and clamp it back down onto the Antenna mounting bracket since it is a very snug fit anyway. My question is will the 3M tape hold this or should I look into getting some screws to screw down into the roof. I would rather not do it, but I don't want to loose my antenna to the wind. lol I must say it is solid as a rock up there right now. I thought about simply putting a zip tie around the rail and the top portion of the bracket just as a precautionary measure. Just curious what you guys think. My LI heads are also on the front with the 3M tape and they are also solid as a rock.
Thanks!
