Results 1 to 8 of 8
    AL Priority with ALPConnect vs Vitronic Poliscan
    100km/h zone - front facing Vitronic PoliscanSpeed setup on tripod on the verge on the left (base of light pole).Support car backed well into the bushes (see rear video).Poliscan is setup on a gentle curve, and quite angled across the carriageway to minimise lidar detection range
    ALP alerts through ALP bluetooth module and ALPConnect app on iPhone.Note ALPConnect directional warnings are reversed as the designated front heads have been deployed on the rear, and vice versa
  2. The Following 6 Users Say Thank You to winterbrew For This Useful Post:
    BestRadarDetectors (01-08-2014), dinkydi (01-08-2014), Mirage (01-08-2014), RedRocket (01-08-2014), RigToFly01 (01-08-2014), shanetrainST (01-08-2014)
    Is it actually jamming or just alerting to the beast?
    Not going sufficiently fast enough here to demonstrate it's capabilities
    Defence mode was active
    at least ya got heaps of warning great vid
    Dec 2013
    Toronto
    We are lucky not to have it in Ontario000
    Another superb vid from WB nice work mate
  8. The Following 2 Users Say Thank You to shanetrainST For This Useful Post:
    BestRadarDetectors (01-08-2014), winterbrew (01-08-2014)
  9. #7
    Dec 2013
    great vid what dashcam are you using, fairly good quality.
  10. #8
    Thanks - front is an iTronics ITB-100HD.
    Rear is the original BlackVue DRG-400HD which was demoted to the rear screen, as it doesn't handle bright sun as well as the iTronics
    There's probably a bit of lost quality, as I had to merge the 2 videos with software, and the ITronics is 24 fps, and the BlackVue is 30 fps, and they both use different codecs, so what the program spits out will be a bit of a compromise
