Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Post ALP Bluetooth Module & ALPConnect App Review by Mirage
    by Mirage
    So you've all seen the pictures and the videos, but how does it actually work? Well I spent some time with the ALP Bluetooth module and the ALPConnect app and decided to do a video review of the system. IMHO this is another huge leap forward on behalf of AL. The other guys better get to work as they are falling WAY behind!
    As promised in the video here is the breakout board I'm using for the RJ45 connection between the Control Unit and the Bluetooth Unit.
    This is much easier though:
    Name:  Premium-RJ45-Male-to-Female-Cat5e-24awg-Ethernet-Extension-Cable-for-Local-Area-Network-LAN.jpg
    Now a few things I did not cover in the video. First if you are using an iPhone you will also have GPS stored with your alerts and it will show you the MPH or KPH speed you were at when hit with the Lidar gun. Also, the settings menu also contains a Bluetooth strength menu. This can be accessed by swiping the app to the left or right.
    Pros:
    1. Visual, Voice, and directional notifications of the encounter.
    2. PREMIUM voice alerts. Much better than other units. Very clear and pleasing alerts. (At the least the female one).
    3. GPS speed and history of alerts.
    4. JTK mode on the app! Super cool!
    5. Audio can be redirected over Bluetooth to the stereo or to an external speaker for increased volume
    IMHO the things that are not so good:
    1. If you forget to connect your iPod / iPhone via Bluetooth (or if you lose connection) to the system you are NOT protected. Unlike the control unit if the Bluetooth is not connected the system is effectively OFF.
    2. No pass through to the control unit for firmware upgrades and setup.ALP changes. In addition, some functionality of the control unit is lost as the ALPConnect app doesn't have all the settings like the control unit. Hopefully this will change in time.
    3. The "music" portion of the alert has got to go. We don't need that! It's more important to have the Voice and a quick and/or repeating siren.
    4. No Android version. Sorry I hate the "i" stuff.
    What is hopefully coming soon:
    1. Ability to do firmware upgrades with the Bluetooth connected.
    2. Ability to change some of the sounds. (Music and Main Alert would be a good start)
    All-in-All this is a great first pass and a huge step up from the parking switches and dials of the other systems. They seem antiquated after using the BT module.
    More details can be found on my blog at http://www.miragetools.net
    That is it for now. Let me know what you think...
    Mirage
  2. The Following 12 Users Say Thank You to Mirage For This Useful Post:
    curmudgeon (12-19-2013), deano (12-19-2013), dinkydi (12-19-2013), Firemedic (12-21-2013), JohnBoy (12-19-2013), max (12-19-2013), radargeek (01-16-2014), RedRocket (12-19-2013), RigToFly01 (12-19-2013), viske (12-30-2013), winterbrew (12-19-2013), Yellowcab (12-19-2013)
    Thanks for the review. Next update will have an option to select a different alert sound if you dont like the musical one and will have several missing features that were programmable when using the Control module. Firmware updates will definitely work when connected to the Bluetooth module and there are several other additional improvements planned for the next update.
  4. The Following 3 Users Say Thank You to BestRadarDetectors For This Useful Post:
    JohnBoy (12-19-2013), Mirage (12-19-2013), Yellowcab (12-19-2013)
    Georgia
    Thanks dude! I already have this setup, and I was not aware of the quick "double tap" JTK. That is sweet!
    My toys:
    2009 BMW 328i Convertible
    SmartRadar by Escort
    Check out My Install
  6. #4
    Quote Originally Posted by JohnBoy View Post
    Honestly I discovered it by accident because I had been informed it was NOT in this release but I guess AL snuck it into production! Regardless I'm glad its there because my kill switch also kills the app as you would expect. I would much rather do everything from the app especially since I plan to do the STiR integration.
  7. #5
    Georgia
    Quote Originally Posted by mirage View Post
    Same here. Once all is done, this is simply one bad ass system
    My toys:
  8. #6
    Dec 2013
    Toronto
    Nice video, very helpfull...
  9. #7
    thx for another great review m, Alp moves onto the 21st century, wonder how long the other guys will remain in the wake, oh dont like the tom tom beats , sooner just have the gun announcement ,
  10. #8
    Senior Member GA Speed's Avatar
    Georgia
    Could you use a splitter to connect both at the same time?
    Sent from my Note 3
    ALP triple's front and rear
    STiR+
    V1
    Redline
  11. #9
    Quote Originally Posted by GA Speed View Post
    I tried. They use a standard 8 pin RJ45 connector and I figured they might be using some sort of serial protocol, but when I tried to split the connections the Bluetooth takes over and the control unit no longer operates. I even thought maybe they were using something like a network switch and tried that and unfortunately that didn't work either. Once they get the updates working through the app it won't be necessary anymore and it can be removed, but until that time you still need it to access certain functions.
  12. #10
    I updated the main post to include the breakout board I'm using.
  13. The Following 3 Users Say Thank You to Mirage For This Useful Post:
    dinkydi (12-19-2013), RigToFly01 (12-19-2013), winterbrew (12-19-2013)
