Results 1 to 10 of 16
    But say you wanted to run rear heads too, then you have to bring the CPU inside under the dash area--Correct.
    Correct. It would make no sense to mount the CPU under the hood if you wanted to run wires to the rear of your car. If you are running rear heads you would want to mount the CPU under the dash so that cables would be long enough to reach both the front and the rear. I mean you could get extensions and leave it under the hood but I dont really see any benefit to the extra costs of the cables.
