Page 31 of 31 FirstFirst ... 21293031
Results 301 to 307 of 307
  1. #301
    You can switch Profiles in BT
  2. #302
    Jan 2017
    Ok great, can you link me to infonthat describes jow to use more than one profile in BT when no hifi is used. Does a usb stick need to be plugged in. Thank you
  3. #303
    Quote Originally Posted by R6n350GT View Post
    Just load a setup file with Profiles selected and the Profile option on the screen in BT will be selectable and it will switch between profiles.
    R6n350GT (02-02-2017)
  5. #304
    As Tom says, just check the 'use profiles' on the alpupdate configure page ;
    Setup your three profiles as you want on the 3 pages (profile A, B & C), download the config.alp file from the website, put on USB stick, plug into the ALP, and you will be able to switch between A,B & C on the ALPConnect app. You can then remove the USB stick
  6. The Following User Says Thank You to winterbrew For This Useful Post:
  7. #305
    Jan 2017
    oh you can do that without Hifi ! Awesome.
    i was reading this and thought he said thats not possible with no hifi
    http://www.vortexradar.com/2016/01/a...aser-priority/
    ok great thanks !
  8. The Following User Says Thank You to R6n350GT For This Useful Post:
    winterbrew (02-02-2017)
  9. #306
    ok great thanks !
    Profiles are just not supported on the standard wired controller. You need either HiFi or BT to use them.
  10. #307
    May 2017
    So I have the iPhone 7 Plus. I have the ALPConnect app installed. Is their a way to have the app go into landscape mode? Cause as far as I can tell the app is only in Portrait mode. While it's not the worse of deals, I usually use it in the background with my GPS navigation on the screen in landscape mode so if I have to switch back to the app I have to rotate my phone to portrait to be able to see what I am doing. Is it possible to update it so that landscape is supported or am I missing something?
