Eh I find the privacy key doesn't work when you use the bt module.
Pull the key and it will still arm regardless.
Sent from my GT-I9505 using Tapatalk
Are you using the Gen II OTA BT module or the original ?
Just tried my original BT module with ALPConnect on iOS 7.1.2 (iPhone 4S), and the privacy key worked as intended when inserted and removed
