Results 1 to 10 of 307
    OK, I'm running K wide, so no segs on K band (just Ka segged). Is it not logging the high and low range k band (segs k1 and k6) that AL recommend to switch off in the firmware update description for to avoid lane assist etc . The Redflex runs in the low (sub) k range in AU, so that probably needs to be included in the logging, if not a bug
    Its definitely not a bug and we discussed this many times. One alert several miles away could cause several logs with loosing weak signals and picking them back up over and over. KA & Laser Alerts are high priority and K band which is loaded with false alerts would easily fill out the log with some decent daily traveling. If you want to make a suggestion for a change I created a thread for suggestions for future features:
    http://radarandlaserforum.com/showth...he-AL-Priority
    Post your suggestions in that thread.
    winterbrew (03-19-2014)
