Page 4 of 31 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 307
  1. #31
    How often do I need access to the SN and PIN? I was planning on making that side the side with the velcro or should I use the blue side for attachment.
    Only once when you register the bluetooth connection with your phone. The serial number will show up in discovery, You only need the pin to establish the connection. Just write the pin number down somewhere in case you change phones.
    RigToFly01 (12-12-2013)
  3. #32
    Time to go buy another second hand iPhone unless there is not a big wait on the Android version? This would look good on my S4 also, will the app in the future contain the record function and direct send to AL, this could be a handy feature for on the run.
  4. The Following User Says Thank You to shanetrainST For This Useful Post:
    Antilaser (12-13-2013)
  5. #33
    Member Antilaser's Avatar
    Croatia
    There are many planed Future options and mods for the app, be free to suggest your own and it may get included at some point. Thanks
    http://www.antilaser.info/
    Enjoy The Power Of Your Car
  6. The Following 2 Users Say Thank You to Antilaser For This Useful Post:
    curmudgeon (12-13-2013), shanetrainST (12-13-2013)
  7. #34
    LI, NY
    The app is in the app store now.
  8. #35
    Quote Originally Posted by hitechrr View Post
    I dont see it? I only see 1.0.1 (October 28th, 2013) which is not the current version - You need 1.1.0 which was submitted a week ago.
  9. #36
    Dec 2013
    At this point its one controller or the other. Control Module or Bluetooth Control Module.
    How should the sounds work? I assume if app is open sounds will play through the phone and into the radio if phone is playing music also. If app is closed, no sound to an alert - correct?
  10. #37
    Quote Originally Posted by flyingunder View Post
    Here is a quick demonstration of the sounds when playing music with the app running in the background.
    The app should start up automatically once it see's the bluetooth connection. If after it starts up if you physically turn it off then of course you will not get any alerts.
  11. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    curmudgeon (12-13-2013), max (12-17-2013)
  12. #38
    Dec 2013
    Thanks. Looks like app is ready now!
  13. #39
    Yes, Just checked and its showing the updated version in iTunes...
  14. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    dinkydi (12-13-2013), RigToFly01 (12-13-2013)
  15. #40
    Connecticut
    Mine is installed and running. Very easy. Plug and Play!
    Name:  2013-12-13 15.59.11.jpg
    PowerUCC Panorama G DashCam
    --> RALETC TESTED! <--
    Install
    Prius_C_Install
    Testing
    April_4_2014
    April_13_2014_RALETC_MEET
  16. The Following 4 Users Say Thank You to RigToFly01 For This Useful Post:
    curmudgeon (12-13-2013), dinkydi (12-13-2013), shanetrainST (12-13-2013), winterbrew (12-13-2013)
