You do not need to do anything after an encounter. Hopefully you set your LID settings to 4-5 seconds and it will defend you long enough to slow to a safe speed and they will get a reading on you at the reduced speed and you can go on your way. Unless you drive in areas where Laser Ally guns are used heavily you will never need to send us anything. If you want to help other drivers in your area use a smartphone app like Waze and let others know of the trap when you find one.
