If your system is running and operating with Bluetooth module then you had an update at some point and would no longer need the control module. If its brand new your installer should have used the Control Module to install the initial updates. If your system is running with the Bluetooth then you should be fine. Whoever installed the system should have installed the USB Extension cable somewhere convenient for you to load updates.
and everything is buried in the dash. Im using the bluetooth module and don't have the the wired controller hooked up is there anyway to do the update when connected to bluetooth or do you have to have the controller hooked up ? please advise thanks in advance
