Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: gu day
    gu day
    joining in from Australia ..
    got the news letter from brd thanks mate
    forum looks in good shape nice work
  2. The Following 2 Users Say Thank You to deano For This Useful Post:
    curmudgeon (11-10-2013)
  3. #2
    Behind a LIDAR gun
    Welcome to the forum. Hope all is well in AUS.
    Telling the truth and exposing the lies in the LIDAR industry
    www.Raletc.org
  4. The Following User Says Thank You to Yellowcab For This Useful Post:
    deano (11-08-2013)
  5. #3
    Deano,
    Thanks for passing by. I know you have been using your ALP for a while and if you could share some of your experiences I would appreciate it.
    If I can assist you with anything please let me know.
  6. The Following User Says Thank You to BestRadarDetectors For This Useful Post:
    deano (11-08-2013)
  7. #4
    Administrator Mirage's Avatar
    Welcome Deano
  8. The Following User Says Thank You to Mirage For This Useful Post:
    deano (11-08-2013)
  9. #5
    thanks to all for the welcomes
    brd the ALP is an awesome unit I currently use 5 heads on the rear on a landrover discovery .I did want to use the ALP on the front but as it happens I already have the quad LI installed and some places I had to cut and drill holes so im stuck with the LI on the front for now but happy both ways ..
    from testing mine and a friends ALP they are a very powerfull unit I did see a couple of PTs at first with my 5 head system but we worked it out that the ALP has port detection ie if a front port jammer head detected only the front ports would alert and fire
    my 5 head system on the rear I had the 3 front ports on the left side and the 2 rear ports on the right side but because of the design of the vehicle some heads where hidden because of a mounted spare wheel on the rear and some of these heads are angled out left and right for the good old poliscan infact out of 5 heads only one head is mounted level and straight the othe 4 heads angled out at 12 degrees and 35 degrees
    when I targeted the right side only 2 heads fired and because my number plate is located on the far left side ..bearing in mind there is a big 4wd wheel mounted on my rear right
    I figured that if I swap some ports around on the cpu so when I get a lidar shot on the right side at least one or two more heads fired on the left and vise versa after swapping some ports to allow the heads to allow more coverage I was JFG with 3 different lidar guns all day long
    the detection range also seems to be allot stronger than other jammers I have used ..some times my rear heads alert on a rear poliscan but I hadn't passed the poliscan for anther 100ft or so
    other wise im very happy with the ALP not with the price tag though but that's an Australian rip off thing maybe I wont use some of add on features but cant go wrong with the ALP
    deanoobaby
    ps
    I will drop by every now and again I very rarely get on forums much I haven't been on the other forum for some time now but still drop in every now and again
    flat out at the moment with work and baby stuff LOL
  10. The Following 4 Users Say Thank You to deano For This Useful Post:
    BestRadarDetectors (11-09-2013), curmudgeon (11-09-2013), dinkydi (11-08-2013), Yellowcab (11-08-2013)
  11. #6
    cosmos
    yep same joined last night, i didn't know about this forum until i read a post in our sec from wb referring to the alp,
  12. The Following User Says Thank You to dinkydi For This Useful Post:
    deano (11-08-2013)
  13. #7
    hey dink fishing was good mate I will post some vids and pics on both forums ..I will have to keep some vids private as some shark vids may affend others ie utube users
    anys ways nice to see some good old friendly names on this forum
  14. #8
    cosmos
    got the vids yet, if so link please
  15. The Following User Says Thank You to dinkydi For This Useful Post:
    deano (11-12-2013)
  16. #9
    Land of taxes
    Welcome deano...............glad to see the down under club growing
  17. The Following User Says Thank You to curmudgeon For This Useful Post:
    deano (11-12-2013)
  18. #10
    Hi deano,glad you found the Forum & Welcome aboard.
  19. The Following User Says Thank You to RedRocket For This Useful Post:
    deano (11-12-2013)
