Results 1 to 2 of 2
    Buck Eye State...
    Question LED Operation and Configuration after Firmware Ugrade.
    I seem to have personal issues after I update Firmware getting the 2 LED's to operate correctly. I saved the Configuration file before update, but it did not get me back to operation I want of LED's.
    What I want is the Control Panel LED to blink dimley when ALP is in operation. This allows me to glance down and confirm unit is providing protection. The other LED that comes from CPU ( is this the Status LED?) to be dark unless there is alert. The closest I have been able to get is for both LED'd to blink dimley Please help to get this setup back to what I am used to.
    Tnx
    Quote Originally Posted by Rocketman59 View Post
    Tnx
    On the configuration setting under the LED section choose Dimmed. Once you do that you will get 2 selectors to adust the brightness for the Controller LED and the External LED. If you want the external LED off its the lowest setting.
    Sent from my SM-G988U1 using Tapatalk
    Rocketman59 (04-26-2020)
