Quote Originally Posted by fondoo View Post
I just upgraded the firmware update from
FW Version 5.5.3
PDC FW Version 8.3
to FW Version 5.5.6
PDC FW Version 8.6
and now every time the car starts up, I get a message "warning restore default and memorized sensor"?
is this normal??
Because past update required a full reset. You need to run the factory reset that its asking you to perform and then reload a current settings file and you will be all set.
