Results 1 to 6 of 6
    Dec 2018
    Net radar DSP low k band
    NET RADAR DSP WITH ALP
    When used, the results were impressive but there was only one problem
    ,;The results were weaker than the other machines by a large margin even with the back monitoring was able to determine the distance between the other devices could not
    WITH LOW K BAND
    When the BAND is confined
    24000 TO 24050
    not recognize them among the other devices were able to identify this BAND and was alerted to them
    There have been more than a dozen radars carrying this wave but could not recognize it when it is confined to the range mentioned
    You've always come across an integrated device that does not need other devices
    NetRadar DSP is based on the Attowave DSP platform (same as Uniden R3). Due to hardware limitations, it cannot scan below 24.050 GHz on K band.
    The new Uniden R7 removes this limitation.
    The Radenso RC-M / Pro M or Genevo Pro M / One M also scan down to the lower K band range (23.950 GHz), as do may Escort products, along with the later firmware V1's
    Dec 2018
    But according to the settings of the net radar it monitors this frequency but I think here is wrong in the update or just needs to adjust according to the settings shown in the options of the frequency
    Dec 2018
    Yes, I've seen the settings before.
    The FCC test report says 24.050 - 24.250 GHz on K band;
    https://fccid.io/2AHMC-NR-DSP/Test-R...Report-3483363
    As far as I'm aware, there were never any 'international' models developed for the overseas market, with different frequency ranges
  6. #6
    NR does not scan lower that 24.050. The K Band ALP muting segment's were when we used old Sti-R M international antennas.
