Did you run a factory reset to memorize the hardware change. Anytime you change any hardware you need to run a factory reset or you will get a sensor check fail because your. Hardware configuration changed. TX Sensors also can only be used on #2 ports so in the front it needs to be plugged into the F2 port.
