Results 1 to 3 of 3
    Junior Member indytoatl's Avatar
    Jun 2014
    How many amps does the ALP unit drain from the battery?
    I have three questions:
    1). If you connect an ALP unit to a constant 12v source does the unit pull any amps before you connect with the bluetooth app?
    2). Has anyone found a reliable 12v switched wire under the front hood of a Tesla Model 3?
    3). Has anyone done an installation on a Model 3 and if so, can you share the details?
    Quote Originally Posted by indytoatl View Post
    1. ALP should be connected to a switched circuit. In a Tesla you wint drain the 12v Battery because if it runs low it automatically charges from your large battery.
    2. Check with Tesla forums. I know In my S ther is several places to get switched power. Even cigarette lighter has no power when out of the car.
    3. There are several but I dont have any photos.
    Sent from my SM-G965U1 using Tapatalk
    Can only help w/ 2 answers:
    1. From www.alpriority.com website (under FULL ALERT status - max current (amps) drain is 1.5a)
    2. In quiescent standby state - current drain likely only ~couple hundred milliamperes (.2a)
  4. The Following User Says Thank You to RedRocket For This Useful Post:
    tphank1 (11-27-2018)
