Hi There,
is there any solution for your problem found, cause it seem‘s to happen i‘m having a similar problem with my new installed ALP - have checked all cabling and power voltage - but simply no life from the control set but once the bluetooth module is connected the green light is flashing slowly.
if i start the IOS App its is showing white car and bluetooth connecting- disconnecting in a 1-2sec cycle - no function of the App operateabl.
kind regards, Mike
- You may not post replies
- You may not edit your posts
Forum Rules
