Results 1 to 5 of 5
    Member gapi's Avatar
    Mar 2016
    Rear Parking Sensors Config When Using a TX & Splitter for the RX's
    When using 2 RX and 1 TX & Splitter for the RX's on the rear do I choose R1 & R2 in the sensor config?
    Member System's Avatar
    May 2017
    Alberta
    Yes choose both sensors. Just make sure the TX is plugged into R2
    Mar 2016
    I see.
    While I waited for a reply I did a config choosing only the R1 as a rear parking sensor and it functioned or alerted to objects in front of it on both RX's.
    If I do not choose R2 as a rear parking sensor will the TX on that port be disabled?
    Thanks
    Mar 2016
    I see.
    Actually----- Does parking detection have to be enabled on the both TX ports for the TX to defend?
    Thanks
    Quote Originally Posted by gapi View Post
    I see.
    Thanks
    Parking setting for R2 & F2 when using TX sensors makes no difference since there is no receivers in TX sensors.. The setting is only for parking alerts, it has nothing to do with activating a port.
    gapi (12-03-2017)
