Results 1 to 7 of 7
    ALPconnect Android Lag & Disconnection issues
    Hi Guys
    Anyone else having issues with ALPconnect on android devices? I have been an apple user and had little issues but now going to android its horrible.
    The main problems are
    -It disconnects/reconnects 3-7 times before finally going into green then blue defense, when i start my car.
    -ALP take a good 15 Seconds to realize power has been removed from the CPU (turning off car)
    So far I have tested on 3 devices and on the latest ALP firmware.
    -Samsung S6 (android 7.0)
    -UMI Z (android 7.1)
    -Sony Xperia XA (Android 7.0)
    All have the same issues
    I have been all over my wiring and connection and it all seems fine, I also run a antitheft usb key if that makes any difference.
    My system consists of a version 1 CPU and Version 2 Bluetooth
    For me the ALPconnect on the android does not feel as polished as the apple version in regards to the Bluetooth communications, but maybe I am the only one
    Hi Guys
    I don't have any issues with Andoid on mine.
    Any ideas on what might be causing it tom?
    As soon as I use my iPhone SE or my 7plus it fine, but on all the android device I own it does the same thing.
    The only thing I can see that I have that probably different is the anti-theft/privacy mode key is enabled.
    Unless it’s my Bluetooth unit itself??
    At a complete loss to figure it out, it would be easy to explain if it was just occurring on one device.
    When it tries to connect/disconnect I hear ALPConnect attempt to connect, then it flashes red then off (cycle repeats until it finally connects)
    Could this be an error
    The anti-theft mode doesn't work correctly when using BT.
  5. The Following User Says Thank You to beingaware For This Useful Post:
    shanetrainST (10-22-2017)
    I need to turn that feature off then,guess that’s back to the factory for a reset?
    Unless I can turn it off somehow
    Once it's on it's on.
  8. #7
    Canada
    Where is your bluetooth module located? I was having disconnect issues as well, with my Galaxy 5A phone mounted to the right of my steering wheel, and the bluetooth module under the glovebox. I moved the module to the drivers side of the console, under the dash and now no issues. I suspect there was interference from the 2 video screens in my centre console between the phone and bluetooth module. Whatever the issue was, my android connection is solid now.
