@FastKatt
I'm not familiar w/ your States enforcement tactics so for now you can take a pass on Rear protection until you determine if they are needed in the future. (on a large vehicle like your's, you probably would need extension cables)
Not much Forum activity b/c of the 4th of July holiday & everyone is on the road traveling w/ family likely.
You have to do your homework if you choose to use a "Pro" to do an install for you. Most audio install Shops are "100% clueless" on how to do a proper install. Over the years I've seen so many horrible installs by so-called "Experts" that turned into expensive disasters for the customers.
There are no Forum members very active here for the localities in which you drive who could recommend a true expert professional Shop for your area.
However, the U.S. Distributor @BestRadarDetectors does have a list of Dealers & maybe 1 might be in your area.- (contact him here by sending a PM)
Otherwise, you need to be your own expert on how to direct the Shop to do it properly !
An other option is to join another Forum where there are many active members who reside in your State & maybe 1 member "might" know of a competent Install Shop nearby you.
Good Luck.
Reason: spelling
- You may not post replies
- You may not edit your posts
Forum Rules
