I wanted to try and test my ALP with a Bushnell ProX 2 Rangefinder that cost $500. My ALP is set on PDC & LID, LID time 4, After LID time Warm Up, Pro Mode Enabled, Skip First Warm Up Enabled, Voice PackMode Enabled for the HiFi control set. 2 sensors in the front and 2 in the back.
The Bushnell ProX 2 is a really nice rangefinder to test with though I am not going into full detail because I only had a limited amount of time to test with it.
The rangefinder only works for distance and Not for speed. I only wanted to test if it will pick up the laser on the ALP using the Bushnell ProX 2.
In a quick way to explain about this rangefinder...I find a spot from a distance and the finder will get a distance with a cross hair on the eye hole. Once it finds the spot you want to get a distance the ranger will lock the spot and vibrate to confirm the distance. If you point the finder to a spot to get a distance it will get a reading but it does not lock the spot and does not vibrate it will not be a confirmed reading. This is the quick way how I understood how this rangefinder works.
Here's how I quickly tested it out by myself.
My ALP was on and my recording app on my phone was turned on to record the sound.
I walked several feet away from my car and pointed the finder to a few objects to test the finder out. Remember The finder will get the distance, lock the spot and vibrate to confirm if the finder gets the distance but if it does not lock the spot and vibrate its not a true confirm. When I got done testing the finder, I walked several feet away from the front several yards away and pointed it to the plate, head lights, fog lights and side turn signals. I got a reading on all those spots but it did not lock the spot and vibrate. ( the ALP was jamming the finder ) I also did that in the rear by walking several yards away and pointing it to the plates and back lights and turn signals. I got a reading on all those spots but it did not lock the spot and vibrate ( the ALP was jamming the finder ) I tried it with the ALP off and tested the front and rear and it got a reading, locked the spot and vibrated. ( this confirms that the finder got a confirmed reading ) I checked if I had any punch through's but did not have any.
To confirm that my ALP worked and jammed the Bushnell ProX 2, I went back to my car and listened to my phone recorder and too gladly say that my ALP did jam the Bushnell ProX 2 and with my HiFi Voice Control it announced ( TruSpeed S ) In the Front and in the Back.
This is a quick way to check if your ALP is jamming correctly by using a Bushnell rangefinder. By the way, I purchased the rangefinder to test my ALP and I returned it the same day and got my money back.![]()
