Results 1 to 3 of 3
    Quote Originally Posted by gapi View Post
    FYI: My CPU is HW2, I'm running the latest FW, Voice Pack, and Quint with a TX front & Rear.
    Before adding the rear RX & TX, in ALP Connect (ALPC) mode I had the external LED on the lowest setting, and when switching to HiFi I had the External LED off with just the control set LED on.
    Now these external LED settings seem to follow the last loaded config.
    I use modify in ALPC to setup my config with the external LED on lowest setting and run it. Good.
    Then I shut the car off, open the door to make sure the power is off.
    Kill the ALPC.
    I load my USB config setup with the external LED off and its fine.
    Now I switch to the ALPC mode and the External LED is off. Some one tell me if what I had before is a fluke or ......
    If you hit Modify in ALP Connect it does not load your current configuration. It will load your set ONLINE configuration. I would bet your USB configuration and your online configuration are different. Set all your setting in ALP Connect and when done go back to the app and hit download.
    gapi (08-28-2017)
