Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
  1. #21
    Member angrypenguin's Avatar
    Oct 2016
    Quote Originally Posted by V1Jockey View Post
    I have an Infiniti Q50S with 2 RX mounted below the plate and 1 TX at the top of the grill. Tested with Alex at KMPH and was JTG against his newest DE and Truspeed SX, CM and headlights / fog-lights. Previously my dual setup had been JTG against the Truspeed but CM only with PT's on lights with the DE. The TX is very impressive.
    Which DE? DETC or Speedlidar?
    I JTG Speedlidar without an issue on my setup. The main difference between my setup and yours is that my TX is mounted 21.5" above the ground. Yours is much higher.
    I've been chatting with various experts and I think it's safe to say that TX heads should AT LEAST be 24" off the ground.
    I will be replacing my grill with a carbon fiber grill that doesn't have the fucking three pointed star. Should make the install much easier.
    Given my results we don't believe it's an issue of receiving the signal, but the tx must be fucking around with the rx with unwanted reflections.
    It doesn't explain why I can JTG the Speedlidar though.
  2. #22
    Member gapi's Avatar
    Mar 2016
    Quote Originally Posted by angrypenguin View Post
    ^ Sheriff's association eh?
    Yes, long time member for support because if I get robbed or whatever they are the first people I (we) call.
    The perks of the tags have helped in the past. They have got me off more than once I'm sure but its all in ones run of luck.
    I don't run them anymore. These days you don't want anything that helps certain people to remember you.
  3. #23
    Canada
    My TX is 25" off the ground. Tested JTG against Dragon full size (2017) and Truspeed SX.
    Sent from my SM-A520W using Tapatalk
  4. #24
    Oct 2016
    Dragoneye full size (speedlidar) was not an issue for me. JTG for everything. The challenge is not with that gun.
  5. #25
    Junior Member Marcv125's Avatar
    Oct 2016
    We have been talking with many customers with TX Sensors and discussing test results and one think is becoming clear... When sensors are mounted overall more than 30" apart it is creating some center issues. When using TX Sensors the Maximum distance from sensor to sensor can not exceed 30" Recommended spacing is closer to 24-26"
    Attachment 5814
    so Tom saying this, we still should mount the TX sensor at least 20inch off the ground still correct?.. And we now want the TX in line with the RX sensors?.. Just trying to understand this better. And are you suggesting a second tx sensor for certain applications now?
    thx Tom
    Radar Cm:
    Valentine 1 3.8952
    Redline
    Sti MAG
    Radenso Pro Se
    Net Radar
    Laser Cm:
    Alp Triple Front
  6. #26
    Quote Originally Posted by Marcv125 View Post
    thx Tom
    TX does not have to be in line, separation is actually preferred with TX being higher in most cases. Minimum of 20" is still required if someone wants to use the TX. No one needs more than one TX sensor on any end of a vehicle.
  7. The Following 2 Users Say Thank You to BestRadarDetectors For This Useful Post:
    Marcv125 (08-27-2017), modsl55amg (03-04-2018)
  8. #27
    Oct 2016
    ok so just for clarification purposes, if i have my tx sensor mounted higher than my RX sensors, i want no more than 30 inches from outside rx to middle tx to outside rx?.
    Radar Cm:
    Valentine 1 3.8952
    Redline
    Sti MAG
    Radenso Pro Se
    Net Radar
    Laser Cm:
    Alp Triple Front
  9. #28
    Oct 2016
    30 inches is stretching it a bit. TX sensor higher is good.
  10. #29
    Mar 2016
    VERY few cops will target you @ CM from a very far distance when they're shooting your ass. Why? Because they have a HUGE ground to cover in order to catch up to you.
    Hoping for this scenario is not a good idea.
    @angrypenguin. I agree with you so don't take this as an argument. Sometimes on these forums my grammar gets folks hair up even if I sugar coat it.
    I knew when I ordered my TX for the rear I would be rolling the dice but what the heck I have this spare RX left over from the front TX install so.....
    Anyways in reflecting on all the encounters I can remember since 2004 or 5 (can't remember) when I installed my Lidatek LE30 Dual jammers and measuring on maps my best guess for an average distance is about 1000feet. I do get targeted regularly here in town in two places both 1800 feet. From what I gather 1000 feet is on the short side but in the city its probably not so much.
    Anyways............. Right Wrong or indifferent with the dragon's beam width specified at 2.5 ft. (30 inches) @1000 feet the picture below is a close representation of what I can hope NOT for eh? And if he is not using a tripod, rifle stock, or laying across his hood (LOL) I may get lucky.
    We will be testing Next Week.
  11. The Following User Says Thank You to gapi For This Useful Post:
    angrypenguin (08-27-2017)
  12. #30
    Oct 2016
    Quote Originally Posted by gapi View Post
    Cool! PS where did you find this Dragon reference?
