Understood. I guess in my case, I'm trying to figure out this exact scenario versus VPR guns:
1) Two regular heads up front
2) Two regular heads + tx
I saw on one of the YouTube videos that ALP dual heads are 70% effective vs VPR guns - but I don't see any test results proving this. It also doesn't specify the type of vehicle. As you know, in my other thread, I'm dealing with a compact/small ish sedan, so not sure if I need to buy a tx head. When I bought the ALPs, a dual head setup for sedans was already sufficient when jamming VPR guns but I can't even find those testing results anymore
I also learned that the tx head is the only head that fires when dealing with a VPR gun like the dragoneye. So now in this case, the advantage of the tx is that there's a third head firing in a vertical direction vs two regular ALP heads with 1 transmitter in each. (so the benefit of a tx head is 1 net additional transmitter in this example)
Non VPR guns are not the concern that I'm trying to deal with. I understand that there's some secrecy needed for some reason (saw on another forum) about ALPs vs VPRs. While I have no reason to be a skeptic and to doubt the SMEs on this board, as a consumer about to drop $550+ CDN for a tx head + gps receiver, I would really like to see some testing results in this regard
Thank you
