Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Quote Originally Posted by angrypenguin View Post
    Just going to throw this out there (only mean this respectfully)
    If that's the case, then there has not been any information available to us as consumers because organizations like RALETC haven't published testing information to support or deny the claim that DE guns have changed between 2014 and 2017 which has resulted in efficacy changes with CM; and even if that is verifyable, then now we, as consumers, have no idea how two head ALP setups fare vs these type of 2017 VLPR guns, let alone a two head + 1 tx head setup.
    I know you probably have far more connections than any of us do but would respectfully request that you pass on a message to the testing gurus to begin publishing some information so consumers can make educated choices.
    Right now from what I read on here and on other forums it's very much a "buy a tx head if you want effective protection against DE" - without testing, however impartial it may be, consumers like me who are evidenced based buyers will not just hand over our money
    I can only speak for myself but I remember back in the 90s when RMR had huge marketing campaigns that showed how their RDs could jam radar...they simply said "believe us!" and people bought it. Many of us on these forums were smart enough to see some proof, and thus bought CMs that work. I feel that right now we're at an impasse because there simply isn't published information to help us consumers make educated decisions about how best to fight DE.
    Whether or not two heads is sufficient, and if not, what are the improvements with the new tx head?
    We are not RALETC, If you have questions for them then you should direct it towards them. They do have their own website. Even mentioning ALP & RMR in the same sentence is insulting. There is lots of research and testing out there if you spend some time and look for it. Our reputation also speaks for itself.
    Sent from my SM-G955U using Tapatalk
  2. #12
    Member angrypenguin's Avatar
    Oct 2016
    Sorry meant no disrespect as I mentioned the word "respectfully" a few times.
    Just looking for said testing results and there doesn't appear to be many, if any out there since 2014 to address these basic questions.
  3. #13
    Member
    Mar 2015
    Canada
    I tested my dual setup last year with Alex from KMPH in Vancouver, and against his 2016 DE I was JTG on CM but PT on headlights around 1300'. This year, with the addition of a TX head and against a newer 2017 DE the same car is JTG period. Google their website and check out the video section. I'm a satisfied customer.
  4. #14
    Dec 2016
    I plan on testing my setup with and without a TX against a DEC in a hilly and overpass scenario which is the type of protection I am looking for from the TX. Just haven't found the time yet.
    Sent from my Nexus 6P using Tapatalk
  5. The Following User Says Thank You to studio1930 For This Useful Post:
    tphank1 (09-08-2017)
  6. #15
    Oct 2016
    So I just did my own testing with the help of a veteran of this forum! . Dual standard ALP with the new tx head in the middle.
    While I'm still investigating the results, I can say that the tx head did not perform as I expected (not saying good or bad here). I'm in the process of trying to figure out things, but I'm not going to post exactly what went well or what went not so well (if any) Once my findings are complete, and if I feel that it is worth sharing with the public, then I'll post about it.
    I will say this: I encourage people to test their own setups to know what works and what needs to be tweaked in their setups (potentially).
    Assumptions may well get you in trouble!
  7. #16
    Nov 2016
    In this test that did not perform as expected for you, what are the distances you tested at for the sensors, F1 and F2, and the distance between F1 and TX? PM me if you do not want to post. I have a setup on my vehicle I am curious about before buying one of these TX sensors. Thanks.
  8. #17
    Oct 2016
    26" end to end.
    IIRC 12.5" from bubble of ALP head to TX
  9. #18
    Jun 2018
    Hi...i am a new user here. As per my knowledge an ALP 3 Regular Sensor will Jam all guns and a 2 Regular + 1 TX Sensor will also jam all guns. Benefit to the TX is it will offer better off axis and overpass protection being that it has both Horizontal and Vertical transmitters in the new small TX sensor. It also offers users with only 2 rear sensors the option to add a TX giving them similar protection on the rear utilizing only 2 wires.
    percentage calculator
