Results 1 to 10 of 14
Thread: Tx advice
    Member angrypenguin's Avatar
    Oct 2016
    Tx advice
    So just fooling around on kmph.ca and found out that ALP now sells a tx. I've had the dual setup up front and have had good success vs the dragoneye. It's not THAT common in my neck of the woods but some surrounding detachments have them.
    The main issue now is that if I add a tx up front, there's only 7" between the bubble of one of the heads and the tx. The pricing of the tx also means that I could buy an additional two ALP traditional heads.
    1) Do I really need a tx to be safe against the Dragoneye?
    2) What is better? 3 or 4 regular heads up front or two regular heads + tx?
    One of the photos showed coloured lines indicating where I can put the tx. There are two blue options, both of which only means 7" between that and the alp head. The yellow line is almost impossible to mount although I understand that is ideal. Alex at KMPH suggested the third tx head could be on top of the grill right below the hood in the center, but that's not a do-able mount.
    Would appreciate any suggestions. Thanks
