Quote Originally Posted by sfpd View Post
Two weeks ago I added a NetRadar antenna to my system, and I've been having trouble getting GPS radar suppression working effectively. I typically drive the same route to work daily, and this one particular stretch is rife with random radar sources (primarily K-band person detection radar at crosswalks). Even after using TeachSuppress 6+ times on this stretch, my system still alerts for the same sources. Manually tapping the 'suppress' button doesn't seem to have any noticeable effect either. Attaching a video of my drive today-- the system does seem to be registering the sources when TeachSuppress is on (note the tons of pins already on the map), but the alerts keep coming regardless (all the additional pins/alerts being logged as I go)
Any thoughts on how to fix? Is it possible to tune my settings so each suppression pin has a larger diameter mute area, and/or to mute for a wider range of frequencies?
Did you originally have a different radar antenna? If so you will need to start from scratch and wipe out all old data.
