Originally Posted by
RedRocket
They are there w/ nice pictures showing the mounting positions, but probably buried deep in some of the Threads.
***Now that I know you're here in the USA, your L.I.s WILL NOT protect you from the DragonEye Lidar gun that MD Troopers use today. Same applies if you drive in Virgina or Delaware...You're burnt TOAST!!!
If you drive faster than PSL you need a 3 Sensor Front AntiLaser "Priority" protection, L.I.s cannot handle the above Lidar guns.
The MD Poli's are usually White Vans or White P/U trucks w/ caps on the rear bed, they shoot you in the back as you pass-by.
