Using ALP Radio Mute and Control Functions
I am getting ready to install my new ALP system. I have brought it up on the bench and upgraded the firmware. Everything is working as expected. I just wanted to validate my approach with others with respect to using the radio mute and control wire.
For the radio mute, my radio has a telecom mute that expects a ground signal in order to mute. It looks like the ALP radio mute puts out 5VDC UNTIL it is activated and then the voltage falls to 0VDC (ground) when triggered. I am not sure I can have 5VDC sitting on my radio mute most of the time prior to sensor activation. This means I will probably need to isolate this circuit with a 5VDC relay that, in turn, drags my radio mute to ground from an open state. Is this the way others have approached this?
For the control wire, it is opposite. The control wire sits at 0VDC UNTIL activation and then puts out 5VDC. I want use this 5VDC to drive a relay that cuts out my rear brake lights for the duration of activation that I have set (7 seconds). In case I get hit from the rear, I don't want the LEO to see my brake lights come on.
I just wanted to validate this approach with others and see what others have done.
Thanks!
Volt meters on blue/green wires
My ver2 hardware bought in May/15
Using ApexOnYou Post #22 as a reference
Standby:
Green: 0v
Blue: 4.65v
Alert: (3sec LID)
Green:0v
Blue: 0v
15 sec after Alert! (great for a radio mute)
Standby:
Green: 0v
Blue: 4.65v
https://www.youtube.com/watch?v=Yivl...ature=youtu.be
Conclusions:
1. Blue radio mute wire gave a signal when it saw an alert, green did not
2. Blue wire signal lasted 15sec
3. Problem Definition: Why did Green wire do nothing, yet my manual says "Green relay wire in the Rev2 ALP control box can be connected to the coil of an automotive relay which is then pulled to the +12v car battery. By using this relay it is possible to switch off/on other vehicle circuits during an alert from ALP. The relay wire pulls to the ground when active the same as the mute wire."
4. Diff topic, my 3sec alert keeps saying "...interference detection ONLY"...yet my 4sec LID timeout gives a nice machine gun sound, of course I am in blue mode.
Indicator lights on relay helpful
deano,
on further reflection, your version has nice indicator lights....red & blue for power and switching probably.
Question, where do I get those three veritcal post PIN connectors (female) for incoming power....?
