AntiLaser has taken several recommendations and has made a few changes to ALP Connect.
The biggest addition was the HFP (Hands Free Protocol) which will enable the ALP Alerts to seamlessly integrate with most vehicles though the vehicles HFP protocol allowing your vehicles stereo to automatically switch to the ALP alerts. Once done your vehicle should go back to the source you were listening to without needing to do anything. (This will be a work in progress because all vehicles have different systems so it might work great in one vehicle and another might not like it) Time will tell what the best method will be but we are adding all available options.
I can only see this being a great feature for those using Laser Defense only. My initial impression since I see so much Radar daily and I use the ALP Radar Integration that I would not use this option because I see so much radar local I would not get a full song in without it switching over but for Laser Only it would be awesome to make sure you do not miss an alert if you are cranking up the volume.
Attachment 2057
Also many have asked that for the Radar Frequencies & Laser Gun identification be larger and easier to read so that was also changed:
Attachment 2058 Attachment 2059
Previous versions when pressing the Mute or JTK the system would stay in Mute until you pressed the button again. This was corrected and Mute is only a Temporary mute until the alert stops and they mute will automatically shut off.
Also added a new Demo Mode so users can get familiar with the current sounds of the different alerts and there were some very minor bug fixes. It should be coming out shortly.
