Originally Posted by
brettzo
The issue is persisting and sporadic with connectivity to the BT module. It's very odd in that I drove in the city most of the day yesterday running errands, meaning vehicle on/off several times and the app connected via the BT module with ease. Now this morning when I start up my vehicle, the app will not pair and the BT module green light will not illuminate (this has happened the last 3 days in a row). I then have to remove the BT module, insert the Cset module, press power and when powered on, remove the Cset module and replace the with the BT module again. This keeps it functioning for the remainder of the day, but obviously an annoying and counterproductive step to have to be taking.
I have spoken with the distributor who has recommended to leave the Cset module inserted for a couple of days and run that way to see if the issue persists with that module. If not, then try the BT module again and see if it goes away. I can also try an alternate CAT cable (I would imagine that I can use any CAT cable...5, 5e, 6?). I will also try to reset to default and upload the update/setting files again if I can't get the issue to go away within the next few days.
I will keep you posted. The system is otherwise working fantastic and great JTG performance on our tests.
