I know DragonEye have opened an office here in Australia, but has anyone heard of any rumors to purchase their products? Or worse implement them?
Heard there are units out on loan to interested parties for trial.
I think we should now be protected with the latest AU firmware update for the ALP should they appear in the wild.
Like the dala vibes wb , got all the updating tonight when I get bak
Here's the SA approved list ;
http://www.austlii.edu.au/cgi-bin/si...9355/s13b.html
Seems to have been a recent addition of Redlex stuff on the SA list ;
Quote:
(db) REDFLEXpoint-to-point camera system manufactured by Redflex Traffic Systems Pty Ltd, linked to and used in conjunction with an induction loop vehicle detector;
(e) REDFLEXred-speed HDX system manufactured by Redflex Traffic Systems Pty Ltd, linked to and used in conjunction with an induction loop vehicle detector;
(ea) REDFLEXred-speed HDX system manufactured by Redflex Traffic Systems Pty Ltd, linked to and used in conjunction with an induction loop vehicle detector, a Variable Speed Limit Sign and a closed-circuit television camera;
cheetah c- 50 the little helper
Watch out VIC's, was having a dig around on that website, searched for DragonEye ;
http://www.austlii.edu.au/cgi-bin/si...013450/s4.html
Quote:
(2) For regulation 41(b)(vi) of the Road Safety (General) Regulations 2009 substitute —
"(vi) the Pro-Lite +;
(vii) the ProLaser 4 (also known as the PROLASER 4);
(viii) the DragonEye Compact (also known as the DragonEye COMPACT); and".
from what i have read, not all units approved for use actually get used. Gov is on the war path so time to be careful.
that's true, just have to keep peeper's sharp and report
Well researched. I got caught up at
I think that means if you're only high on (3,4-methylenedioxyamphetamine; tenamfetamine) MDA, then you're fine to drive?Code:"prescribed illicit drug" means—
(a) methylamphetamine; or
(ab) 3, 4-Methylenedioxy- N -Methylamphetamine (MDMA);
(b) delta-9-tetrahydrocannabinol;
The full list for VIC is at http://www.austlii.edu.au/au/legis/v...09289/s41.html
Good to see the prolaser ii is still good... although not sure what it means by "auslaser", mine shows it's display in km/h but it says nothing about auslaser
Code:ROAD SAFETY (GENERAL) REGULATIONS 2009 - REG 41
Prescribed speed detectors
For the purposes of the definition of prescribed speed detector in section 3(1) of the Act, the following speed detectors are prescribed—
(a) a digitector; and
(b) the following laser devices—
Reg. 41(b)(i) revoked by S.R. No. 118/2013 reg. 4(1).
(ii) the Prolaser 11 Model Auslaser;
Reg. 41(b)(iii) revoked by S.R. No. 118/2013 reg. 4(1).
(iv) the Prolaser III;
(v) the Pro-Lite;
Reg. 41(b)(vi) substituted by S.R. No. 118/2013 reg. 4(2).
Reg. 41(b)(vii) inserted by S.R. No. 118/2013 reg. 4(2).
Reg. 41(b)(viii) inserted by S.R. No. 118/2013 reg. 4(2).
Out of the list of guns I would watch out for Prolaser 4.
