Temp Fix for using both the Bluetooth Module & Control Module
A few of us have purchased these 2 Port Network Switches on Ebay and I can confirm this switch works:
http://www.ebay.com/itm/Mini-Dual-2-...item23347dd7d1
They are $3.55 cents shipped and I just received a few and I can confirm that they do indeed work. You can connect the Bluetooth Module to one Port and the Control Module to the other port. Then a jumper cable to connect the switch to the Control Module. You can press the A or B button on the switch to switch between the different modules.
Guess for the price its worth buying in case you run out one day and forget your phone or iPod behind and its a simple push of the button to switch to the Control Module until an official fix is released from AntiLaser.
Attachment 597
http://youtu.be/YXDvOQBj96A
