Can't wait to see some old faces and meet some new ones. Weather looks good and the turnout looks great!
Can't wait to tare up some installations. If we can't get a PT on your set up, no one can!
Will your set up be RALETC APPROVED?
Looking forward to seeing some old friends some new friends and THE ROOKIE!
Come with questions about radar, LIDAR and our CMs. This is a great opportunity to learn a lot.
check your PMs
Has the location pm been sent out?
Check your PMs.
We retested the LI after running the sensitivity test on the test course. With the heads pointed upwards at 5 degrees and towed outward at about 2 degrees. The LI did not alert to any interferences. The LI had instant and constant punch throughs on three consecutive runs when tested with the DET Compact.
We are speculating that the cause of the punch throughs are due to the installation that we use for testing. Based on the instructions that LI provides for the firmware update, we feel that they want the heads positioned in that fashion to minimize interference between the heads. It is possible if the heads are installed so they are also recessed and isolated from each other it may result in improved performance.
Everyone is too tired to post up? Haha good day, except finding out I suck at updating :/
